NEW Product Release: Hi-Tek Deep Transmission Pan for '07-'17 GM SUV and Truck 6L80E
Available March 1st, 2017
B&M Hi-Tek Deep Transmission Pan for 2007-2017 GM SUV and 2009-2017 GM 1/2 Ton Trucks (part 70392)
Application: GM SUV and 1/2 ton Trucks w/ 6L80E transmission
Description:
This B&M Hi-Tek deep trans pan is designed for GM SUV and 1/2 ton Trucks with the 6L80E
transmission. The pan adds 2.0 US quarts of additional fluid capacity and boasts an over 30
percent improved cooling efficiency over the stock transmission pan by using a proprietary
high quality cast aluminum. The Hi-Tek 6L80E pan also incorporates external cooling fins
which not only look good, but are also functional by increasing the surface area to help
dissapate heat much quicker than the OEM stamped steel flat transmission pans. Additional
features includes an engraved B&M logo, a magnetic drain plug for catching ferrous metals,
a temperature sensor port and stainless steel mounting hardware. Does not fit Camaro
6L80E trans. Gasket and filter not included.
Please call 707-544-4761 or visit www.BMRacing.com for additional application and product
information.
• Increased Cooling Effect
• Engraved B&M Logo
• Additional Fluid Capacity
• Magnetic Drain Plug for Easy Servicing
