Rebuildable 4l80e core
Rebuildable 2004 4l80e core, includes stock TC if you want it. Trans was slipping heavily in 2nd gear under any power and couldn't complete the 1-2 and 2-3 shifts at WOT. No neutral safety switch or vent tube. Comes with the factory cooler ports, not the AN ones pictured. Does have the speed sensors. The main electrical connector externally is cracked and will need replacement. Tailhousing was removed to confirm fully splined output shaft. Trans has the "ears" cut off on the sides of the case near the bellhousing for extra clearance.
$250 picked up. Factory 4l80e flexplate $25 - this is the updated version from GM due to the old ones cracking.
SOLD
SOLD
