Tru-Cool Max Trans Cooler 4739 & 47391 Install Kit - Brackets & Fittings & Hardware
MASS seller approved
Currently, these brackets allow for a Tru-Cool Max (Part # 4739 or 47391) to be installed on 99-06 (07 Classic) Silverado/Sierra 1500/2500/3500 Trucks with a 4L60E, 4L65E, or 4L80E transmission. Will not fit trucks with Allison trans. Will also fit the NBS SUVs such as Tahoe, Yukon, Avalanche, and Escalade. Also updated to now fit 2007-2014, see notes below!
If you already have a factory trans cooler, this kit includes everything needed to install the Tru-Cool Max cooler. There are two brackets, two quick disconnect fittings, a compression fitting, and the necessary hardware needed for install. The only thing you need to supply is a tubing cutter. One trans line needs to be cut and spun 180* to fit the wider stance of the cooler.
If you do not have a factory trans cooler, you will need to mod/replace one trans line, and buy a factory line that goes from the cooler to radiator.
The complete kit is $79.95 shipped in the USA. You can order here with free shipping: Tru-Cool Install Kit Order Page (You can pay via paypal, venmo or credit/debit card at this link)
Alternatively, you can use also pay via Paypal using this link: $79.95 Trucool Install Kit
Install Guide: Tru Cool Install Guide
*Stock Status*
Kits are instock!
***FITMENT UPDATE***
Here's how to tell if these will fit your 2007-2014 Silverado, Sierra, Escalade, Yukon, Tahoe, Avalanche, Suburban:
If the bottom bar of the stock trans cooler is BOLTED on, these brackets are a 100% direct fit/bolt on.
If the bottom bar of the stock trans cooler is WELDED on, these brackets will fit one of two ways:
1) Cut/Grind the welds and remove your stock bracket. Use self tapping screws (or another method) and bolt my bottom bracket on
OR
2) If you do not want to cut/modify your stock supprt, Replace the entire support. They can be had for about $60 shipped. You want part #: GM1225262 This includes a bolted on bracket. Here's one on ebay for $60.32 shipped: SUPPORT BRACKET ON EBAY
Here's a picture showing where to look if you're bracket is bolted or welded on, look at the two yellow circles: BOLTED ON BRACKET
*Stock Status*
Kits are instock!
OR
If anyone has a NNBS 07+ Truck or SUV and you are close to Romeo, MI/Macomb, MI, and want a set of free brackets, please contact me for details. I need a truck/SUV for a day for test fitting.
Had one on my old '08 silverado, loved it.
They should still fit the same from the other NNBS trucks to SUVs though but id be more than happy to test fit and get some pictures of the install on mine
I have 08 Av and have the factory cooler, I will buy
the set that exactly fit my model. Please let me know oNce you have it ready.
It will be great if you make an install video!!
