2002 Reg. Cab Silverado Totaled! Parting out here! Paypal Accepted!
The items for sale in this thread have been moved to a thread titled "LSX related vehicle parts"
2002 2wd Reg cab SWB silverado 4.8/4L60E pewter ext/Beige or tan interior.
A friend of mine just totaled this truck this week. We will be disassembling the truck over the next few days. I will list all parts that are in usable condition and be as up front and honest about the shape of everthing being sold as I can. I personally rode in the truck before the accident and it ran really strong and the transmission shifted perfectly. He had only had the truck for about a week before this happened.
Prices DO NOT include shipping unless it says so next to the part. Send me a private message including the ship to zip code and I will send you back a shipped quote.
Obviously some items cant be shipped or would be extremely expensive to ship. If you want to pick parts up yourself, the ZIP where the truck is located is 30176
Truck shows around 160,000 miles on the odometer. It is unknown if the engine and transmission in the truck are the originals or not.
$1000-COMPLETE takeout 4.8L engine with ALL accessories down to the belt and fan clutch. Engine has EGR delete. Includes intake, injectors and rails, coil packs, throttle body. Headers will be removed and sold seperately. Engine wiring harness, fuse block. Computer has a dent in the side of it, but probably still works. 4 or 5 of the wires on one of the PCM connectors got cut in the wreck and will need to be repaired. MAF sensor connector has been cut off, but is included, along with MAF sensor. Power steering reservoir is bent from the wreck. Picture of damage a few posts down.
$500-4L60-E transmission with stock stall and is believed to have a shift kit installed. Shifts great, no problems at all.
$125- K&N intake, SOLD
$175- Pacesetter longtube headers, SOLD
$100- Pair of flowmaster 2 chamber 2.5 inch mufflers. Or $50 each
$20 shipped White face guage overlay- Still in plastic -SOLD
$10 ea. Driver and Pass side inside doorhandles
$100- Drivers door. Just the shell. Paint is chipped a little where door and fender meet each other. Top of door has a crack in paint too.
$40-Drivers side mirror, power.
$25 A/C accumulator. Tape placed over openings as soon as it was removed
$50 A/C line from compressor to accumulator and compressor to condensor
$25 A/C line from evaporator to condensor. Includes orifice tube.
$75- Brake booster
$50- Brake master Cylinder.
$75-Drop in Bedliner
$200- Cloth 60/40 bench seat with flip down console. Tan cloth. Console lid latch is broken.
$300-Drivers side airbag - Tan
$300-Passengers side airbag - Tan
$100- Drivers doorpanel- complete - tan
$100 -Passengers doorpanel -complete - tan
$50- Cluster with white face guages. All guages work. Piece missing in edge of cluster, cant be seen when installed. Pic below
$30- trim around radio and inst cluster.
$150- Complete carpet- Tan, very clean.
$50- Windshield wiper cowl trim and wiper arms
$50 - Winshield wiper Motor.
$200- Steering column complete, no airbag.
$1000- Rolling frame, including 4-16 inch steel wheels with tires, brakes all the way around, rearend, front and rear suspension. The leaf spring on the driver's side has some damage, and the axle flange on the drivers rear is bent a little, when the wheel rolls, it wobbles some. The truck can still be pushed around by hand. The front swaybar on the drivers side is also bent a little. Truck was lowered with drop shackles in the rear, most likely stock in front.
$250- Gas tank including evap canister, evap lines, fuel pump and sending unit .
Open to reasonable offers on any of the parts.
I will include pictures of parts as they are removed. More parts to come.
$75- Brake booster
Last edited by ILLWIN; Apr 3, 2009 at 09:41 PM. Reason: Consolidating for sale threads. I moved these items into another thread.
Yeah, the wrecker driver said the same thing "if i'd a been drivin that truck, the seat would a been a darker brown, and it'd prolly smell pretty bad in there too"
I added some pics here, the drivers side doorpanel, the damage to the wires on the PCM connector, damage from the wreck to the PS reservoir, the 4L60E trans, and a picture of the inside of the engine, with the pass. side valvecover off. This engine is super clean inside, looks like it has 50K on it.
