catch can...
Old 07-03-2006, 06:11 PM
11 Second Truck Club
Superado's Avatar
Default catch can...
not sure if you guys have seen or used this one. I saw it last night in a Jeg's, it was listed as "new"...
It looks alot like the ones at Home Depot and that bothers me because the ones there have a warning label on them stating that the bowl is NOT compatible with petroleum products...for air/water separation only.
Due to the stated use for this, I would think this one is different, but who knows? But, at $39.99, it is much cheaper than the aluminum ones...
Air oil separator is designed specifically for vehicles with positive crankcase ventilation systems. Prevents oil blow-by from being displaced into the intake tract on engines where crankcase pressure is high such as (but not limited to) power adder or high RPM applications. Features a clear polycarbonate bowl for durability and easy viewing, serviceable 5 micron element and a twist/turn drain. Easily cleaned with household soap (dishwashing liquid), thoroughly rinse and air dry (do not use compressed air). Includes mounting bracket and two 1/4"NPT x 3/8" hose barb fittings. Always route away from heat sources. Maximum pressure of 150psi.
Old 07-03-2006, 06:32 PM
TG02Z71's Avatar
Good find.
Old 07-03-2006, 07:35 PM
I AM A MOTHERF*CKER
TurboBerserker's Avatar
Nice! I need one of those... I finally found one I liked -- out of stock until November lol
FlyingLow
11-24-2015 10:05 AM
nic351
09-24-2015 09:43 AM
97_ek
09-23-2015 09:16 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
ferrellrooster
07-13-2015 09:53 AM
Quick Reply: catch can...
