Lq4
Old May 2, 2006 | 09:28 AM
gonzo 6.2's Avatar
Default Lq4
05 longblock with covers.Ins. pull out 50K miles was running but rough and slight knock according to the service manager.Water came in through the air box.Local pick up prefered.or arrange your own shipping.Already crated. $650
Central Oregon 97702
Old May 2, 2006 | 02:56 PM
onebadrubi's Avatar
their is no way to find out if it is actually pretty Fed up or run a compression test on this is thier?
Old May 2, 2006 | 04:00 PM
gonzo 6.2's Avatar
I would guess it needs a piston and a rod maybe a crank turn.I believe the guys as to the story.It ran with a little knock noise.This would be a good canidate to find a LQ9 rotating assembly,I have seen 2 on here in the past for $100 crank ,rods ,pistons w/rings mint.
Old May 2, 2006 | 04:16 PM
onebadrubi's Avatar
Can you get me a pic. IS this coming with EVERYTHING from injectors to 317 heads, intake manifold, knock sensors, fan, pcm?
Also an approx wieght? I have a ups account just gonna try guessing the shipping cost.
Old May 2, 2006 | 04:19 PM
gonzo 6.2's Avatar
Longblock means block with heads,no intake or pulleys.I am guessing 600LBs
Old May 2, 2006 | 04:21 PM
onebadrubi's Avatar
Sorry man but id like the intake to. SOrry to bother.
Old May 2, 2006 | 04:26 PM
Zick's Avatar
Why? Just use the one off your 5.3 as they are the same basically.
Old May 2, 2006 | 04:47 PM
onebadrubi's Avatar
Dont the 6.0l flow better up top?
Old May 2, 2006 | 05:14 PM
bigredexpress99's Avatar
they are no different. Part number is the same, look the same, function the same.
Old May 2, 2006 | 09:55 PM
onebadrubi's Avatar
IIf you can get me a picture I can possibly let you knwo tommorow and get payment out within the end of the week.
