Silverado SS, Joe Gibbs Editions, SSR Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Need a part #
Old Oct 26, 2005 | 10:55 PM
moregrip's Avatar
what a rush!
Default Need a part #
looking for an 06 Silverado SS Silver Birch Metallic front grill assembly?
do these come painted or do they need paint?
Old Oct 27, 2005 | 08:35 AM
leftcoast32's Avatar
FormerVendor
If you find one unpainted get ahold of me and we can go pick up your paint.
Old Oct 27, 2005 | 08:42 AM
Fogle07's Avatar
most of the ss grilles come painted. i know they did for the black, red, and blue ones.
moregrip's Avatar
what a rush!
lol, thanks joe, I'm working it, trying to see what's available, .........maybe just sanding down the chromed plastic would be the best way to go, it seems to rub off quite easily anyway
Old Oct 27, 2005 | 08:47 AM
moregrip's Avatar
what a rush!
thanks for the 411, I have a local project going here with prepping and painting a bumper and maybe my stock grill, just not real sure on the paint adhesion to it after the chrome is sanded off, probably pretty good, as it seems to be quite thin and easy to rub off with no sand paper at all
Anyway, the bumper is made out of TPO plastic, which I know has to prepped very well and can be tricky to get paint to stick to it.
Old Oct 27, 2005 | 09:16 AM
Fogle07's Avatar
sand the grille down with 320 grit and you should be fine. you could even scuff it with red scuff pad really really good. try to get it as dull as possible or even remove it. when you go to paint it make sure you put some adhesion promotor on there so it will stick good
Old Oct 27, 2005 | 10:01 AM
moregrip's Avatar
what a rush!
might have to give that a try, I'd rather not buy one if it's not needed
Old Oct 27, 2005 | 10:06 AM
Fogle07's Avatar
its not needed. thats how i done 1slow01z71's truck. i just scuffed the chrome and painted it up. good luck with it.
Old Oct 27, 2005 | 10:37 AM
zippy's Avatar
15276049 should cover it. 06 SSS in silver birch metalic.
Old Oct 27, 2005 | 11:11 AM
moregrip's Avatar
what a rush!
thanks zippy, WOW! list on that dog is $405!
