Hesitation/Stumble off idle 5.3
Old 08-25-2002, 06:30 AM
TA/30th 1002's Avatar
Default Hesitation/Stumble off idle 5.3
99 Silverado 5.3 Z71 ...
Has anybody else experienced this symptiom?
As near as I can pinpoint my problem: At aprox. 0.8%-1.6% throttle position the PCM will bump ignition timeing some 15* or so. If the throttle is held in such a position it will occilate between 0.8%-1.6% causing the ignition timeing rate of change to occilate too. This seems to be causing a surging with my engine.
I can duplicate this surge at hot low idle by manualy opening the throttle; by driveing the truck in low range/light load. In low range the surge can become so violent it'll cause the trans to hunt between gears.
>I have fooled with the throttle stop adj. ... no differance.
>I have disconected the throttle position sensor ... problem went away.
>I have compared throttle position sensor incriments to my 99TA ... same calibration.
***My prognosis is the timeing calibration**
Does anybody have any thoughts on this?
Thanks ... Ron
Old 08-25-2002, 10:31 AM
BigTex's Avatar
Default Re: Hesitation/Stumble off idle 5.3
I have something similar. Under load with very low rpms and throttle, timing will go up and down quite a bit. If I give it more gas, the converter will unlock and rpms will go up and it will stop. But if I continue to make it happen, it will eventually show KR and have negative timing. Really weird. I took out some timing and moved up the converter lockup speed. That has helped me some.
Old 08-25-2002, 10:52 AM
Ahh BigTex:
Thanks for the reply. From your reply I take it you have LS1-Edit! I have edit for my F-body, but not my truck. I woundering if the timeing can be altered at low throttle positions [below 1.6%] to smooth the low throttle responce transition!
ie) give it about 6% more timeing at hot idle < 0.4%-0.8% TP ...
ie) give it about 6% less timeing at > 1.6% - 2.0% TP ...
How much timeing did you pull and at what % TP?
Ron
Old 08-25-2002, 11:08 AM
Moderator / Sponsor
oxidizr's Avatar
You may want to do a TSB search ... from what I recall in 99' there is a TSB for PCM reflash for just that. The TSB description uses similar verbage refering to the trans hunting for the appropriate gear at low throtle position. There are quite a few TSB's out there for tranny related operation faults.
Richard
Mossyoakglock
08-28-2015 12:49 PM
superchomper2003
08-26-2015 09:39 AM
smokeshow
08-23-2015 08:23 PM
darnie
08-10-2015 10:25 AM
05GMC4.8
08-07-2015 09:55 PM
Quick Reply: Hesitation/Stumble off idle 5.3
