Walbro 450 Install (in progress)
I can see pic. but the gray part you don't use. you mount the pump in the bucket by zip tie or a homemade bracket. Then run a hose up to the top of the sender but put loop in hose so it will have move to press without kinking hose. cut hose about 2in install tee fitting install hose on tee run over to the long fill tube. I always install a worm clamp at the bottom of fill tube to hold it in bucket.
As for getting the stock sending unit back in, it was a pain but i got it to fit after messing with it for like 30 minutes and As for the bed, yes I did this under a car port and I pulled the bed with a cherry picker
Now i just need to order some barb fittings and drive around bedless for a few days
