Project Silver Bullet!
#101
the goal now is to not get arrested haha. i would like to be able to bump up the boost so i can have a "high" setting (for flex fuel) with my controller so ill need to run a set of dual pumps. talking with the tuner he suggested a dual setup of aem 320s. pumps are an easy swap so may just buy another factory fuel bucket off craigslist and start chopping and plumbing away with a dual setup... in no rush to do this so its time to start reading up again .
_zblee
_zblee
#102
so got engine bay all put together. this is how it sits right now. the only thing i plan on changing is getting rid of the blue air filter (this was cheapest one i could find to get it up and running). going to replace it with a larger filter that has a 4" aluminum piping placing the air filter away from the heat (over in front of the reservoir tank or something). going to get it coated the same black as the rest of the of aluminum. since i am density tuned i can get rid of the maf and have a single OR two piece piping from intercooler to TB. we will see.
blanket stinks! smelled worse right after the initial drive during street tuning. its not bad now that it has a couple of hours of burn in time but i can still smell it (normal according to the paper work it came with ).
here is how the truck sits with the caltracs. rear should be a bit lower now because the rear springs i put back on did not have the overload spring so it should be about 1/2" lower in the rear. sits pretty even.
here is snapshot at the dyno
here is video of one of the dyno pulls
here is the graph that shows the high boost (11~12psi) on e54 where we hit 617/598 but had to back it down because i did not have enough fuel pump to keep the pressure up. it is overlayed with the 91 pump results with 8psi
here are the final numbers as it sits now. 91 vs e54 both at 8psi
and now i will be seeing this scenery probably at least once a week
_zblee
_zblee
#104
I have a gauge for that
I would advise against the aem320 pumps, I have seen plenty of them have issues. I personally like the walbro400s or 450s. The eastiest thing for you to do is add a walbro450 to your current pump and have it activated via boost controller or hobbs switch. Also make sure and upgrade the wiring for whatever pumps you use.
Go as big as you can on the inlet tube and filter, like 5 or 6", with the largest filter you can find. It will make a big difference.
#105
#106
yeah a second 450 is what i was initially thinking anyways. tuner suggested the aem pumps. im in no rush so im just going to be doing a lot of research on both setups.
after some spirited driving i had my boost controller log the highest boost it sees and showed 9.3 so far. so im probably around 9.5lbs and not 8. need to do some longer wot pulls to get the max. with traffic around here i run out of room really quick ...
_zblee
_zblee
#109
8 Second Truck Club
Procharger puts the inlet of the blowers on these trucks directly over the header on the driver side. Time an time again I've seen people route the filter out of the way to avoid the header heat.......then the ones who listen, put the filter directly on the blower and in almost every instance pick up power without the elaborate piping to help pull air from a cooler place. At the end of the day, the restriction of the pipe and bends is more hurt full than the heat.
