Jake's '05 Rcsb s488 4l80 build
Old 08-23-2016, 09:31 PM
  #141
Jake75's Avatar
Originally Posted by Wolftrk99
I dont have an issue with the bolts with them separated, i am just trying to conserve time, i am doing the swap at work(after work hours) and cant tie the rack up and i would need to be able to push it in and out if need be, seriosuly thinking a weekend would be best, but that means giving up time with my kids... Wishing i had bought a house with a garage!!!
Take the kids with u and teach them how to wrench!
Old 08-23-2016, 10:54 PM
  #142
Wolftrk99's Avatar
Would love to, but they have no interest!! However the 15 year old is going to build his first vehicle!!! Whether he likes the thought or not!!!
Old 08-25-2016, 12:50 AM
  #143
8 Second Truck Club
Blown06's Avatar
Man, really you need to get the truck together to figure out if that yolk is gonna work. I'm gonna say it is too long. There are at lease 3 different length yolks for a th400 style output shaft (same as 4l80e I believe). Once you get the truck together you need to make sure that you have enough pull out with the driveshaft bolted in, other wise you will be destroying thrust bearings in the motor on the regular.
Old 08-26-2016, 08:22 PM
  #144
Jake75's Avatar
Well...today at work i was checking out atomic hydro boost swap and decided i was gonna do mine. I ordered the hydro booster from lkq for 35 bucks! When i got home i pulled the vacuum booster and the brake pedal. It took maybe 15 mins! Hopefully the swap goes that smooth. I also got the frame mounts put in and torqued, so I'm ready to drop the motor and trans in. Maybe tomorrow then ill be able to check the driveshaft and yoke
Old 08-27-2016, 01:47 AM
  #145
8 Second Truck Club
Blown06's Avatar
Cool deal man. Why the switch to hydro boost brakes on a build like this?
Old 08-27-2016, 02:56 AM
  #146
Jake75's Avatar
The little bit of reading on the swap I did everyone is saying the stopping power is unmatched. It seems more boost can be made with the hydroboost than normal vacuum boost and being that I don't have a transbrake it was worth a shot. And it was a cheap mod so screw it
Old 08-27-2016, 05:24 PM
  #147
GMCtrk's Avatar
On a build like this w/o transbrake you definitely need hydroboost.
That being said, being 2wd i think you will regret not having a transbrake.
Old 08-27-2016, 06:06 PM
  #148
Jake75's Avatar
Gunna try without a trans brake first. Trans builder said no problem to add one later. If i can't get what I want out of the hydroboost I'll be getting the jakes d3 brake
Old 08-28-2016, 01:02 AM
  #149
8 Second Truck Club
Blown06's Avatar
Damn, I assumed this was a trans brake build..........with all the other **** going on.
Old 08-28-2016, 01:44 PM
  #150
GMCtrk's Avatar
Id highly advise gettjng the transbrake now.
Quick Reply: Jake's '05 Rcsb s488 4l80 build
