need pushrod length info please....
Old 03-27-2006, 11:41 PM
Default need pushrod length info please....
I just purchased a Comp Cams XE 224/.563/112. i plan to install this in my 04 5.3 silverado. does anyone know what length pushrods i need to get? also, what gaskets do i need to purchase? any tips on the install? thanks in advance for any info shared....
Old 03-28-2006, 11:02 AM
SSlow 4.8's Avatar
i beleive the pushrods you need are stock length.. get them from thunderracing.com
7.400 is the stock length i beleive.. i have a similar cam and thats what was recommened for me. As far as gaskets go... you might be okay, but if you want, replace the head gaskets, timing cover gaskets, i beleive thunder racing also has a gasket install kit. check them out.
Old 03-28-2006, 11:40 AM
white1's Avatar
Why would he replace the head gaskets??
I think stock pushrods are 7.375. I believe you need 7.400 (if I remember what I have. Call Futral Motor Sports, or Thunder Racing or Comp, or anywhere and they should be able to tell you. Also, Ive done a few cam swaps In these trucks, and never replaced a single gasket, just be careful when you tear it down. These gaskets are designed to be re-used to cut down on shop labor or some B.S. like that
Old 03-28-2006, 12:01 PM
v8
17,16,15,14,13,12,11 Drvr
stock push rods are 7.40
Old 03-28-2006, 12:31 PM
Flyer's Avatar
Stocks are close to 7.35
It depends on that cam really. If the base circle is the same as the stock cam, you will be in good chape, but if it's smaller, you need a longer pushrod.
If it's the same and you go with 7.4's, it will run bad. It will have lack on the bottom cause the valves are hanging open all the time.
Old 03-28-2006, 07:07 PM
v8
well I pulled my stockers out and put them up against the 7.35 rods and the 7.35 are shorter than the stock ones. So I would say the stock ones are 7.400.
Old 03-28-2006, 09:26 PM
Thanks guys for all your help. I'm going to cal thunder or comp tommorrow. And white1, i'm going to try to save my stock gaskets as well. Thanks again...
Old 03-28-2006, 09:50 PM
good luck with the instal enjoy your cam!
Old 03-28-2006, 09:54 PM
Flyer's Avatar
v8, I think you're right after thinking about it some more.
Old 03-28-2006, 09:56 PM
v8
I'm right and a mod said so lol ahahahaa
RustyD
05-23-2016 07:04 PM
JordanH
11-06-2015 07:42 PM
slimchevy2
10-04-2015 08:02 PM
Wolftrk99
10-02-2015 08:17 AM
Silver8ado
09-30-2015 11:42 AM
Quick Reply: need pushrod length info please....
