New 07 Silverado w/AFM & VVT or Classic 07
Old 05-15-2007, 09:21 PM
  #31
eallanboggs's Avatar
Ideally, if this new cam were available you would leave AFM and VVT operational. They don't effect WOT operation, but would benefit fuel economy in low load situations. 23 mph on the highway at 70mph is excellent especially with a 3.73 ring and pinion. A coworker of mine has one of the new Nissan V8 trucks and he get 13 city and 15 highway and that's with a gear higher than a 3.42 because at 70 mph he's only turning 1.5K rpm. His mileage makes 23 mpg with AFM and VVT look real good.
Old 05-16-2007, 06:53 AM
  #32
nighthawk08's Avatar
5.3's dont have VVT!
I was re-reading the article on AFM and saw this which is good info:
For hot rodders wanting to modify their DOD-equipped LH6s, it's important to know that the switching lifter has a lift limitation of 15mm (at the valve). The factory cam uses 12.2mm of that (about .480 inch), giving the LH6 a theoretical valve lift limit of .590 inch. It's worth noting that this limit is for the lifter; a different valve spring would almost surely have to be used at this valve lift. Interestingly, it seems possible to grind a custom camshaft, which would only provide increased lift and duration to the non-DOD cylinders (2, 3, 5 and 8), thus allowing higher lift with standard non-switching lifters in those cylinders.
Old 05-16-2007, 08:36 AM
  #33
niugnep's Avatar
As mentioned the 5.3 only has AFM. Also, if its the Titan, fair is fair they only come in ext cabs so would be heavier than mine for sure, and I know lots of guys with the AFM powered ext and crews don't find the mileage that great. It seems I picked the right gearing, most of my driving is in city, I figured the 3.73's would help compensate a bit for the 20's and give a bit better accel off the lights, seems to be proving out.
Once GM gets the 6 speed out with its low first gear (top gear in applications right now is the same as the 4 speed), could run taller gears and have even better accel yet so that would be a bonus. Be 2009 I'm hearing though...
Give it some time, there will be cams for this stuff. And there is always the hardcore guys who go crazy and get custom ones done, but almost seems best way to make power now is forced induction anyway.
Old 05-22-2007, 09:44 PM
  #34
Horace Mast from Mast Motorsports just emailed me about the VVT/AFM LS engines. He said you can disable AFM by simple unplugging the electrical connector at the back of the motor. Once AFM is disable you can install a non-AFM cam(pre AFM cam). This also requires replacing the special AFM lifters with the old style(non-collapsing type) and installing a valley plate which would replace the LOMA assembly. He went on to say that the AFM cams have 4 different cam profiles instead of the normal 2. You have the 2 normal profiles on the AFM cams as well as 2 additional profiles for the AFM cylinders(one profile for intake AFM cylinders and one for exhaust AFM cylinders) for a total of 4 different profiles. I guess this means the swap is possible.
chadjcompton
17
06-21-2022 08:47 PM
rednekferlife101
32
01-08-2016 10:42 PM
MattOKC
08-18-2015 11:30 AM
Cm_gmt800
08-03-2015 09:13 PM
Matt331
07-26-2015 09:40 PM
Quick Reply: New 07 Silverado w/AFM & VVT or Classic 07
