2014 RCSB tune only racing
Old 07-18-2016, 08:26 AM
Formerly LS1 D3moN (2014-06-05)
D3moN plz's Avatar
Default 2014 RCSB tune only racing
Here's the vid of that race
Facebook Post
Pretty happy with it. i was hoping for a 14.3 - 14.4....so a 14.5, for first time out is pretty decent. Is faster then my old 2001 was when it was a stock ls1 with a tune.
monday morning...leave your race number on...cuzracetruck.
Old 07-18-2016, 09:04 AM
ZO6Ted's Avatar
Very good considering the heat! You'll get those times or better in cool weather. With traction probably see 13.9x's.
Old 07-18-2016, 09:13 AM
D3moN plz's Avatar
yeah...it was insanely hot out there. i'm saving up for goodies....so next time it hits the track, it WILL be under 14 easily
Old 07-18-2016, 09:26 AM
ZO6Ted's Avatar
FYI I was 9.13 @ 75 in 1/8th, 2.0 60' bone stock with a bed liner and cover (150 lbs). I'm 4wd and it was 65 degrees. The weather and traction was great. You'd be quicker and faster.
Old 07-21-2016, 11:43 PM
15dnali6.2's Avatar
What wheels are those!?!? Looks sick! Longtube headers and a tune should put it well into the 13s traction pending...
Old 07-22-2016, 07:59 AM
D3moN plz's Avatar
Thanks! those are Intro Wheels 818s. fronsts are 22x8.5, rears are 22x11.5
Old 07-29-2016, 05:17 AM
Ryan Mills's Avatar
Curious as to what you used to lower your truck? do you drive it on the street? did you notch your frame? I really like the way it looks!
Old 07-29-2016, 10:20 AM
D3moN plz's Avatar
i drive it every day and almost every where i go.
it's got a mcgaughys 4/7 lowering kit with another 1" drop shackle in the back to total 4/8 drop. i dont have a notch, but i do hit the frame every once and a while..
Old 07-29-2016, 11:53 AM
Ryan Mills's Avatar
I have the same, at 3.5/6, but the front tires hit the fender liners on the highway sometimes.... are you running McGaughy's front struts? I'm running 305/40/22 all the way around, maybe that's the issue.... What size are your fronts?
Old 07-29-2016, 12:41 PM
D3moN plz's Avatar
that's your issue. 305/40/22 is a pretty tall tire for the fronts on a dropped truck. 31.57 tall to be exact. for a 4" front drop, typically your front tire needs to be close to 30" tall...or you'll rub alot...like you are now.
305/40/22 is what i run in the rears. for fronts i run a 265/40/22 (30.35 tall). so i have a little over 1" height difference front to back (also why the rear is dropped 8"...to level it out a bit).
that 305/40....nitto?
Quick Reply: 2014 RCSB tune only racing
