E38 Boosted Peeps! TUNE QUESTION! How much boost/power before you ditched the MAF?
Old 06-26-2016, 11:39 AM
  #21
11 Second Club
Mean Green z28's Avatar
Well just to put this subject to rest ... the MAF "IS" capable of being tuned up to atleast 15psi (as in my case) with what seems to be a lot more to go before hitting the max g/s on the table. BUT, this also required scaling the tables down. The issue we were having turned out to be the fuel pump tables that we forgot to scale as well. The fuel pump can boost rail pressure depending on the fuel flow rate, and since we scaled the injectors down, it was never getting to the fuel pump "high flow" table values. scaled the table down and we now have perfect fueling at the top end!
on a side note, I installed a Innovate SCG-1 (boost controller with wideband) that has some need safety features to cut boost by looking at AFR and Max boost pressure and I def saw it work when tuning as it kept cutting boost until the AFR got to a preset s ... best product ever!!!
See below graph, the BLUE is the commanded Lamba, the YELLOW is the AFR Lambda, the GREEN is manifold pressure and PURPLE is Injector duty cycle. This was before we realized the fueling never ramped up.
RPM's kept climbing as this was going on and finally reached a zone where fueling was good to stay below the 0.88 Lambda safety sett point ... until then, the controller kept pulling boost when it saw lean conditions ... really helps to dial in the tables without having to do too many runs.
Old 11-09-2016, 08:37 PM
  #22
vettelovralexand's Avatar
This is interesting. I didn't figure I would run into a problem, but it appears that I am maxing out at a MAF frequency of 12k on my tune right now around 5200 RPM and the AFR starts to drift high.
Old 11-09-2016, 09:17 PM
  #23
Resident Retard
BlackGMC's Avatar
The way i tune the e38 is to disable the maf in the tune. Then tune the VVE up to abouy 4k inly. Then turn back on the maf and the tune the maf. Always works fine for me.
Old 11-11-2016, 10:43 AM
  #24
121
121's Avatar
My 2008 Rcsb was tuned SD right out of the garage 22lbs on e85 drove year round with zero issues.
Old 11-11-2016, 10:48 AM
  #25
121
121's Avatar
Old 11-11-2016, 10:50 AM
  #26
121
121's Avatar
Old 11-11-2016, 10:52 AM
  #27
121
121's Avatar
Old 11-16-2016, 10:00 PM
  #28
fctry286's Avatar
I am still running my maf in my 2011. I have had it up to 16lbs maxed out my fuel system and only hit 12,500HTZ out of the 15,000. I have had zero issues with lean spikes or MAF.
09CamdSilvy
04-17-2016 09:17 PM
01SilveradoJakee
03-22-2016 08:38 AM
Furdkiller
17
03-20-2016 10:16 PM
HDhotrod
18
03-18-2016 10:49 PM
tim wellington
03-01-2016 10:11 PM
Quick Reply: E38 Boosted Peeps! TUNE QUESTION! How much boost/power before you ditched the MAF?
