Cam phaser failure
Old 10-29-2014, 07:48 PM
Default Cam phaser failure
I have a 08 6.0 bone stock showed up at the shop today and looked the truck over with a fine tooth comb NO ONE has been into the motor. It's hard to start, no start, and if you can get it started it runs terrible and will reset the dtc within a few seconds of engine runtime.
It sets PO 0016 CMP/CKP crank cam correlation code.
After going through it I am fairly positive the cam phaser failed and is retarding the cam causing the code. This is first time on these engines I've had one fail anyone have on head south on them yet.
Our gm books and alldata suck on diagnosing this particular code but gotta open up the timing cover to verify my thoughts.
01WS6/tamu is offline
Old 10-29-2014, 08:43 PM
10 Second Truck Club
RS/SS 4.8's Avatar
I thought only the 2011 5.3s n up got the cam phaser. My brothers 2010 5.3 only has dod and no vvt phaser. Either way i have a phaser out of an 08 ly6 on the shelf if it turns out u need one.
RS/SS 4.8 is offline
Old 10-29-2014, 09:08 PM
corrected its a LY6 6.0 had 5.3 on the brain for some reason
Old 10-31-2014, 12:06 AM
Cam phaser was the problem.
Old 10-31-2014, 12:15 AM
gonzo 6.2's Avatar
ok ford guy
gonzo 6.2 is offline
Old 10-31-2014, 09:38 AM
cam
cam's Avatar
What happened exactly? Do you have pics of carnage?
cam is offline
Old 10-31-2014, 02:22 PM
Originally Posted by gonzo 6.2
ok ford guy
Come one damm buy one ford for the wife.
At least it's not the Durango the wife looked at then you coulda burned me at the stake.
My trucks still a GMC FWIW.
Old 10-31-2014, 03:19 PM
gonzo 6.2's Avatar
Rest of your family should burn you at the stake.......well unless you have that manufacture too
Old 10-31-2014, 03:23 PM
cam
cam's Avatar
What the hay is this thread about?
cam is offline
Old 10-31-2014, 07:29 PM
Cam phaser failure. The phaser was stuck at full retard didn't dive into phaser itself real deep. Put on all the new parts and pitched the old one. Fired it up ran CKP relearn and all was well.
Quick Reply: Cam phaser failure
