exhaust question for you guys.
Old 02-14-2012, 09:55 AM
BrutalSierra's Avatar
Default exhaust question for you guys.
I posted in the exhaust section and would like some of your guys input.
https://www.performancetrucks.net/fo...-ideas-497088/
Old 02-14-2012, 03:24 PM
KIFER88's Avatar
idk bout the 4in that may hurt you as it is a daily driver for milage and low end.. id probly go 3.5 myself with a 4in tail.. just my .02
Old 02-14-2012, 03:28 PM
GMCSIERRA5.3's Avatar
^^ x2 4 inch is.too much...maybe if u were going.FI it wouls be worth it..other than that id keep the 3.5
Old 02-14-2012, 04:19 PM
thanks for your input guys.
Old 02-14-2012, 04:26 PM
11Silvy's Avatar
Im thinking about keeping the stock 3.5" piping and go with either a touring or sport corsa muffler. The 3.5" maggy I have now is ok but not muscle sounding enough. I would definitely keep the factory piping however. It's probably good for 500+ anyways.
Old 02-14-2012, 04:59 PM
only exhaust thats factory on my truck is manifold to muffler which is just at rear of cabin. and once my headers come in most of that will be replaced.
Old 02-14-2012, 07:54 PM
Gbody6liter's Avatar
I like my Magnflow. If it's not ''muscle'' enough sounding, go to a smaller one. I don't like Corsa's stuff. Too raw like there's no muffler. Plus, they're just like Borla, overpriced......imo. For another switch, try a Hooker Aerochamber. I've used thoe on my Cutlass and lots of customer's rides and they sound badass.
Old 02-14-2012, 08:12 PM
I'm running a hooker aero chamber now in 3 1/2" but I'll probably be going to a 4" exhaust
Old 02-14-2012, 10:51 PM
4'' is way overkill. A single 3.5'' is good for 500hp easy. 4'' is for f/i or big stroker motors. You will lose all power from 5000 down, where you use it most. You wanna gain power, run a 45 deg turndown on it. You eliminate 5-6ft worth of pipe and bends. The Aerochamber is not a restriction in any shape or form. Unless you plan on making 650hp, then stick with what you have.
Old 02-14-2012, 11:20 PM
62nalide's Avatar
in some cases 4'' is overkill but not with 6.2Ls i have dyno prove where i gained 21rwhp and 16rwtq with just a single 4'' exhaust cat back straight cross the grid im sure BrutalSierra would gain even more with that T-body he just got those headers and 4'' he will see BIG gains
Quick Reply: exhaust question for you guys.
