Adding OEM fog lights to truck???
Pt buds,
My brother recently bought a 2008 Chevrolet Silverado X-cab Z71 and it did not come with fog lights I was able to get him the bumper caps with the fog cutouts and I had some 6" LED PODS that fit perfect in the hole now I need help with the wiring I have an OEM headlamp with foglamp switch but I need to know how/where to find the foglight harness because I want it to look OEM. Thanks in advance for your help!
formerly slow03 (11-04-2011)
IIRC the wiring should be all set in the factory fuse box and behind the dash already. You'll need the wiring harness from the fuse block to the lights themselves and can get it from a dealership pretty cheap.
they do not sell the oem harness by itself.
make your own. it simply ground and power to to specific slot in underhood fuse block. and buy the oem fog light switch. it will work like factory
Thank you so much I never got the alert for this and bought the materials to go a different route but going to convince him to go this route I like the factory look... I have to check to see why I didn't get these alerts via email
ARC
57
02-21-2022 10:54 AM
