transfer case oil color
rear transfer case oil CAM OUT BLACK FRONT WAS MORE BROWN SHOULD THIS BE A CAUSE FOR CONCERN LIKE INTERNAL WEAR , THERE SEEMS TO BE A SLIGHT LEAK FROM AROUND THE REAR TRANS CASE I CANT PUT A FINGER ON IT. I JUST DRAINED BOTH T CASES AN PUT FRESH AUTO TRAK FLUID IN
Caps lock??
We only have 1 transfer case, the one that connects to the transmission.
The others are the front diff and rear diff. Both of those just take gear oil, like a 75W90 and will be brown/black when drained.
The transfer case on a 4WD non AWD normally just takes regular ATF/transfluid. The AWD transfer cases will take that special auto trak fluid. It's not abnormal for the T-case fluid to be colored if it hasnt been changed in a long time.
wrong fluid
i put the auto trac fluid in the front diff then by mistake i havnt driven in 4wd since i put it in, . I'll just drain it n put that 75W90 in the front diff gesssh i fucked up
The transfer case on a 4WD non AWD normally just takes regular ATF/transfluid. The AWD transfer cases will take that special auto trak fluid. It's not abnormal for the T-case fluid to be colored if it hasnt been changed in a long time.[/QUOTE]
Three6GMC
08-28-2015 07:56 AM
04BlackGmc
07-16-2015 04:10 PM
Gadgetized
07-07-2015 04:40 PM
