Tire Size Question
Old 01-29-2017, 07:10 PM
surffly's Avatar
Default Tire Size Question
So I want to install a 5/7 drop on my 06 RCSB V6.
Just picked up a set of transport steelies(22)
Goal is to still actually drive the truck, so want a set of tires that isn't going rub.
265/35?
Something else?
What have you guys run?
Old 01-30-2017, 07:53 AM
someotherguy's Avatar
Man, I'd hope you wouldn't have to go that small. They're gonna look stupid. From experience; I had 265/40/22 on some Dub Ballers and they looked like I had donut spares, too narrow. The 35 series would be same width just shorter sidewall.
Richard
Old 01-30-2017, 03:02 PM
surffly's Avatar
I'm more concerned with not rubbing then having the widest tires.
V6 isn't going to be limited by traction.
Old 01-31-2017, 08:09 AM
I hear you, but what I'm saying is they looked ridiculously skinny on the wheels. I switched to 285/40/22 and it was a big improvement. That's the size Tony (NORCALSS) suggests for the SS's with his 3/4 drop kit, the SS is already a little lower than stock to start with. That size may actually work for you on a regular Silverado with a 5/7, or maybe something a little shorter but same width like a 285/35/22? That's just barely 30" tall and still 11" wide, vs. almost 31" tall on the 285/40/22.
I've done 5/7 on plenty of GMT400's and have a decent feel for what fits, but haven't dropped any GMT800's yet so I'm at a little bit of a loss. Just offering my experience with a similar size as what you were considering and I would advise against it.
Richard
Old 01-31-2017, 04:11 PM
surffly's Avatar
Fully understand the advice, it is exactly why I asked the question.
Someone told me 29inches was the magic number on the!GMT800 when below a 3/5 drop.
Unsure how much lower an SS is to a standard 2wd, would have to assume at least an inch.
Should also say I a man only really concerned about rubs that would hit the fender and risk damaging the paint.
Old 02-01-2017, 07:55 PM
xxch0dyxx's Avatar
I have a 4" drop with 275/40/20 without rubbing. These are around 29" tall... Debating going to 45's to raise it up slightly for a better ride, not sure they will fit though. Ideally I would throw some 50's on.
Old 02-01-2017, 08:18 PM
ILuvJDM's Avatar
275/45/20 is most popular for your drop. 50 series probably won't fit. You don't need 275/40/20 until you're lower than a 4/6
Old 02-01-2017, 08:27 PM
xxch0dyxx's Avatar
Looking at 50 series diameters... and measuring my gap, I would tend to agree with you. I think 45's at this point will be a stretch. Drivers side has dropped about 1/2" more than the passenger side, assuming from whomever put miles on it in the drivers seat.
Old 02-06-2017, 10:36 AM
surffly's Avatar
so the 5/7 requires a slightly smaller tire then the 4/6 drops?
