03+ bcm/interior swap into 99 truck?
Pulled everything out of a 04 Silverado. Completely everything, steering colum/wheel, dash, interior, through firewall harness, door harnesses, mirror/headliner harness, everything. Has anyone done a swap into the 99-02 style trucks?
Custm2500's Rude Friend
99-02 is completely separate/different from 03-07 classic. Even some of the stuff from 03-04 to 05 is different and same thing with 06-07 classic stuff.
Nope! Need the ECU and BCM from the 03- up trucks along with airbag module and possibly the front sensors. You will need a cluster too as those are different. Also the XM stuff if your going to use that as well.
Not trying to hijack the thread, just had a question regarding the swap. If you have the BCM from the 03 and an ecu from 00 lq4, would it work or no? You'd need the 03 ecu and the dbw setup ?
chesterperformance
09-23-2016 08:36 PM
Hillbilly Silverado
08-13-2016 06:33 AM
greenturtle05
20
08-04-2016 09:12 AM
