Tu1 or tick stage 2 turbo cam
Old 05-07-2016, 11:05 AM
Tiddys427's Avatar
Default Tu1 or tick stage 2 turbo cam
I'm looking for cam selection opinions/suggestions.
Truck is an 03' rcsb,4.8/4l80e,3.42.
Goal is 600-650 whp.
I plan to daily this truck and keep the boost turned down most of the time. I typically like a street vehicle to be just a little more aggressive than what most would prefer.
I am in the process of doing supporting mods for an on3 twin turbo kit.
So far I have converted to factory electric fans and done minor cosmetic mods and really just cleaned the truck up quite a bit from the way it was when I bought it. So I haven't really done a whole bunch. I have saved up all the parts required to do the trans swap with the exception of the converter and I'm finding it hard for someone to recommend a converter when you don't know what cam u are going to run. I don't like redoing things and I don't want to spend money on the wrong converter.
I have been researching quite a bit all over about 4.8 cam selections. A lot of guys recommend a z06 cam but I want some lope and something more aggressive.
I was thinking of either a tu1 or tick performance 4.8/5.3 stage 2 turbo cam.
Anyone have any suggestions? Or know of anyone who had a similar combo? I was hoping to make up for the loss in low end power buy using twins. I'm planning to swap to 3.73 gears as well.
Old 05-16-2016, 07:31 PM
fullthrottledan's Avatar
I have been running the tu1 cam for years. Its got plenty of torque midrange and still has some lope even with having -2 degrees overlap. 712hp at 12psi. Im upgrading to a tu2 cam so ill have a tu1 available if you would like.
Old 05-16-2016, 11:13 PM
Tiddys427's Avatar
What size motor?
Old 05-17-2016, 11:18 AM
Originally Posted by Tiddys427
What size motor?
Started in a 5.3, then i just put it in ny 6.0
Old 02-17-2019, 03:28 PM
rjm27's Avatar
Couldn't get any data here on pin55 e38, 2008 silverado rcsb.. what else needs to be done?
Atomic
55
02-04-2021 01:49 PM
SlicksNchicks
03-06-2016 06:14 PM
lxcoupe
03-02-2016 03:20 PM
09CamdSilvy
03-02-2016 09:47 AM
camarojunkie85
13
02-27-2016 06:41 AM
Quick Reply: Tu1 or tick stage 2 turbo cam
