Question on Ls2 lq4
Question on Ls2 lq4
Hey guys, can anyone tell me how much power can a ls2 lq4 and a 4l80e transmission hold before breaking and what can I do to help it from doing so? As in the smartest route.
Thanks in advance.
Thanks in advance.
There is a difference between a LQ4 6.0 and a LS2 6.0, both can handle different power levels.
And early 6.0 from what I gather, so like anything before 2004-2005 can handle 500-600ish horsepower. They came out with a stronger bottom end that can handle 700-800+.
The LS2 should be in the stronger bottem end catagory I think, someone can correct me if I'm wrong.
A stock 4L80e with like a decent shift kit and good tune should handle 600-700+ whp without a problem.
From what I understand...........
pre 2004 and some 2005 lq4 had weaker connecting rods
some 2005 lq4 along with all lq9 and ls2 had stronger connecting rods
If you have the stronger rods then your good to ~750ish whp
If you want to go higher than that you will want to look at forged crank/rods/pistons
Cast iron lq4 and lq9 block is good probably a little bit higher than the aluminum ls2 block (I think Foose04 found this out which is why he went with an iron block 347)
It depends on how much power you want to run and what motor you can get.
Either power adder can cause engine damage if not done right, running a turbo doesn't make it any safer than running a blower. Sure one can make more power but if done wrong you will blow it up regardless.
Sure do whatever you want, it is your money.
But we did try to help here and you don't wish to say what your power goal is.
A monster transmission is not something I'd ever run. Look at different vendor for sure. And like we said before a stock bottom end on the right year engine will take 700-800 whp and at that point it would be useless on street tires.
I hope your budget is well into the 15-20k range if you want a blue printed motor and the best transmission out there. I know most sub 20 year olds are just swimming in cash.
Maybe I'm quick on the trigger sometimes, so it partly my fault.
Was just trying to get the point across that if you just want to be the 500-700whp area that you don't have to shell out the extra money for a built motor. People have taken stock 6.0 blocks so far nowadays with minimal mods and a turbo kit. Unless you plan to make 900-1000whp on a daily basis, I would save your money and spend it elsewhere. You are just adding so much extra money into the situation if you plan to above the 900whp mark, the fuel system costs will sky rocket, getting a built rear end to hold that kind of power and buying a $4,000-5,000 tranmission/converter combo to hold that power.
