Overlap and you......
Hey guys- as most of you know I'm piece- mealing a cam together refining the specs as I decide on displacement and components. The BIG question is about overlap; is it measured from the seat or at .050? When does ovelap begin to affect vacuum? Trying to stay on the conservative side at these higher elevations..................
Oh man you will be fine...
a mild cam in that truck that would work well for you would be something along the lines of a 212/218 low lift. Its a 114 LSA with 2* advance I believe. Vinci offers some small cams that would work well also. Be careful with a cam that has a lot of advance if you dont plan to run headers as it can disrupt your intake flow opening the valve too soon.
Daily driven, mild LS engines seem to respond well cams in the 112-116* range for LSA when running modest durations. High altitude is going to naturally reduce cylinder pressure and idle vacuum.
OP, I would probably do a set of milled/ported LS6 243 style heads first to get the compression ratio up then make a cam change. I would likely run something around 212/218 @ .050 on a 112* LSA and advanced 4*.
Then again you could always do as I have done and swap the junk vacuum booster for a hydroboost setup and run the lumpy cam of your choice.
Yank SS3600 converter, 4.10 gears, Hydroboost, milled/ported 243s, long tubes, a 220/228ish cam on as tight of a LSA as you dare and spin that 4.8 a little.
Holy mother f*** I'm not bracket racing. I purposely sought out a truck with the T engine(*706 heads) for their small valves in the quest for gas mileage. Just lookin' for a little more zing, I have no business in the stoplight to stoplight drag race scene............
