Milling 243 heads and Small shot of nitrous
Old 10-28-2014, 10:19 PM
KleanKustoms's Avatar
Default Milling 243 heads and Small shot of nitrous
Ok, so I'll have my heads in this week and hooefully get them off to be milled in a week or two, but as I'm doing some last minute checking I want to know if I will see any benefits from milling the heads .030 and using a .040 thickness head gasket, or would it be the same for me to mill the heads .022 and run a stock .051 thick gasket, I know if I mill .030 and use the .040 gasket my cr will be around 9:9:1 and if I milled .022 and use a .052 gasket I'll be closer to stock compression 9:5:1. What's better and where would I see more output hp and or tq wise?
Also, plan on doing my own polishing and maybe porting the heads for a little better flow, don't know if that will come into play at all.
Thanks.
Old 10-30-2014, 12:44 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Would help to know your goals to really make a recommendation. Also what motor are you putting them on???
9.9:1 would be a better NA application and cam will respond better to more compression and a tight quench.
Old 10-30-2014, 05:02 PM
Ok, right now the truck is a 05 rcsb 5.3(lm7). The cam I had speced and have for it is 221/221 .575/.575 on 108 lsa. Plan on adding 100 to 150 shot in the future. But nothing more, also will be getting a built trans and 3600-4k stall. Want the truck to show nice gain with the head/cam swap but still would like it to be able to be a DD, and perform nice at the strip if I'd like it to. But mostly for street.
Old 10-31-2014, 05:44 PM
1FastBrick's Avatar
Let me put this in the Nitrous section and see what people have to say over there.
I believe the higher compression will also work with that set up.
chopperloco
07-10-2016 10:45 PM
GrooveCityZ71
08-31-2015 12:05 PM
steves86ta
07-28-2015 10:21 AM
06 4.8
07-15-2015 07:17 PM
07NBSChevy
20
07-08-2015 07:27 PM
Quick Reply: Milling 243 heads and Small shot of nitrous
