4" exhaust systems?
Old 02-06-2010, 03:02 PM
Default 4" exhaust systems?
I know some deisal exhaust systems will work on gas trucks. Might be going to a L92 based 427 10- 10.5 compression plus boost so the need to open the exhaust up will be needed.
Looking for a straight through design that is the quietest possible.
The truck is a 05 serria denali crew cab
I can fabricate the exhaust if needed if there was a muffler only, but a close fit would be better.
Im running a 3" magnaflow exhaust now single out
Old 02-06-2010, 03:14 PM
Praise The Lowered
RibeiroBJJ's Avatar
I was using the Corsa 4" cat back for diesel's and loved it...This was on a SSS radix'd 370ci...Just buy the right cab configuration and you should be good. I bought a Flowmaster dual 3" to single 4" Y pipe and some mandrel 3" bends and did all v-band connections...worked out very well..
Old 02-08-2010, 08:34 PM
03_SS_22's Avatar
my friend had a single 4" on his procharged 370.. it worked really well no restriction really.
i have a mid-pipe from a d-max cat-back, 4" v-band, dynomax bullet, and dump if you are interested.
Old 02-08-2010, 08:40 PM
I have a gauge for that
Atomic's Avatar
I have some mandrel bent 4" tailpipes for sale
FlowmasterMufflers
10-26-2015 06:19 PM
FlowmasterMufflers
08-14-2015 01:04 PM
FlowmasterMufflers
07-22-2015 01:29 PM
FlowmasterMufflers
07-22-2015 12:47 PM
FlowmasterMufflers
07-17-2015 03:26 PM
Quick Reply: 4" exhaust systems?
