help choose between camshafts
i have narrowed down to three camshafts for my truck. here is my info
2002 gmc sierra 1500 2wd ext cab. 370 ci iron block, 11.3 comp, flat top pistons. prc 243 cnc'd heads with stage 2 bigger valves. tbss intake sent to peak speed shop for radical porting. nick Williams 92mm t/b, 1-7/8 full length headers. 4l60e 3200 stall. 3.73 gears. using 93 octane fuel. I would like something that pulls thru mid range up to about 6400 and still have alot of torque.
i am not going to put the names beside the cams, so that it will make for an even playing field.
just looking for advice and what has worked for some of you that may have the same cam or close.
cam (1) 228/232 .626/.626 111+2
cam (2) 231/235 .63x/.61x 111+2
cam (3) 231/234 .629/.615 111 could have it advanced +2 if needed
thanks in advance
thanks in advance
OVOAustin
09-15-2015 08:32 PM
