Flat Top 4.8 Pistons into my 5.3 HOW TO Video Here
#45
Custm2500's Rude Friend
These other two calculators list that info and show a similar number to what the summit one comes up with.
Engine Compression Ratio (CR) Calculator
RSR Static Compression Ratio Calculator
#49
Its coming up with what you said now. Wow man, I'm glad you caught this. It could have been a headache down the road trying to figure out what was going on with a .5:1 difference in compression then I thought I had. I would have been over 11:1! That would be fine for my Camaro, but not in my Daily driver.
#50
I would CC before and after the intake valve change to see were you are at before having any milling done.
Ironically I started this well over a 2 years ago and wanted to do a max effort NA build and see if it could set a record for the fastest stock bore 5.3L. My partner got out of the performance scene. I have now turned it toward a more efficient performance engine build for my DD.
