Cost for around 400hp out of a 5.3?
Currently have a 5.3. Has corsa exhaust and a diablosport trinity.
What do I need to do to get in the 400 range?
Would I have to do some tranny work as well? (Have a stock 4L60e)
And most importantly. Cost. How much would it be to put my truck at the 400hp range??
I want to stay naturally aspirated, and I'm trying to keep cost under 1500-2000, But what it is-it is.
If anyone in SWFL recommend a place to get this done I would appreciate that!
Thanks everyone
Thanks everyone
You can probably stay in that range if you do your own labor.
22x Cam, long tubes, and a good tune should get you close, depending on your gearing and tire size. Trans will not survive, could probably get a little more life from a 40k cooler, corvette servo, and some sort of shift kit. I'd also recommend a set of 4.10s or 4.56s, depending in your tire height.
