coolant throttle body bypass
Old 01-17-2005, 12:27 PM
greentahoe's Avatar
Originally Posted by nightmarechevy
I did it and it does keep it cooler which is good here in TX. I feel that it may have helped a LITTLE but nothing very big. I guess every little bit helps though. I found these dyno results if you want to check them out.
http://www.bmrfabrication.com/tb-dyno.htm
Ive seen that before. I just cant believe it. 6 rwhp from that mod just sounds crazy. Most are thrilled to see a 10 rwhp gain from underdrive pulleys. I guess it cant hurt since its free, but I wouldnt do it anywhere that gets real cold.
Old 01-17-2005, 12:37 PM
nightmarechevy's Avatar
Yeah, not sure how true the dyno report is.
Old 01-17-2005, 03:39 PM
SnakeOiler's Avatar
That dyno chart looks as if it is based on an LT1 engine (96-TA) and not a GenIII engine. As I said earlier, I believe the LT1 benefits a great deal more with this mod.
I would like to see a before and after pull for a GenIII motor, though
Old 01-17-2005, 03:53 PM
hyper's Avatar
unless u live in like arizona, it aint really worth it
Old 01-17-2005, 04:06 PM
I live in TX and it gets pretty hot here, it seemed to run a little cooler after it but I'm not sure it there are any real gains other than that. Its supposed to give 4 rwhp but we all know not to believe what most power adders like this are "supposed to give."
Old 01-17-2005, 04:14 PM
NateZ's Avatar
I would say it's not worth the trouble unless you have to move the throttle body for a FI application, then it's just easier to connect the two tubes rather than extending them to the tb.
nate
Old 01-17-2005, 06:29 PM
Gordy M's Avatar
You do not gain any real HP by doing it. The PCM has firmware to look for it and compensate for it a idle and the amount of cooling on a 90 deg day going 70 mph is zero. More cyber HP than anything.
Old 01-17-2005, 10:06 PM
maximumrebel1's Avatar
It keeps your TB much cooler regardless. Before you couldn't even touch it now its cool to the touch. I doubt 6 HP but it can't hurt. It is the only free mod that I would do again.
Old 02-02-2005, 05:41 PM
not to get off the topic, but i was skeptic about the ram air mod as welll.... (free ram air) my friend has a mitsubishi evolution... and before i did the mod, and new iar filter... i lost to him by a car and a half from a 40 mph roll in 2nd
aferr the mod.. i was beating him by a car/car and a half... if you dont believe me go i will get him to agree to me that this is correct... every little mood to the ls1 helps greatly.... IMPO
it shows on the streets....
i havent done this mod yet... but maybe i will.. if somone can link me to a write-up.... then i will report back with info on performance specs when i take on the evo again!
Thanks
Dan @ www.ChicagoStreetRacing.net
Old 02-02-2005, 05:49 PM
qwank's Avatar
whats the ramair mod?
I did the tb bypass and it gets wicked cold here in NH and i havn't had a problem with the throttle blades freezing.
Quick Reply: coolant throttle body bypass
