Gutted cats
Old 08-12-2005, 09:12 AM
white1's Avatar
Default Gutted cats
I know the right way is to remove them and replace with a straight pipe, but how much of a difference will this make compared to just gutting them out? I have a y pipe with gutted cats, and was wondering cause I also have some 2 1/2 pipe, and am trying to decide if I should just use the y pipe, or replace the cats first.
Old 08-12-2005, 09:30 AM
SBChevrolet's Avatar
you probably wont get much of a differance eitherway as long as you get it all out... you exhaust might have a little more of a hollow note... The only hard part about cutting them out is keepin all the tubes and flanges alligned (unless you do it on the truck) so what I did was run 2 pieces of steel across the tubes in a X pattern and weld it all to geather so nothing could move
Old 08-12-2005, 09:48 AM
14 Second Truck Club
JERRY2500's Avatar
I use a center punch to give me reference marks before i cut the pipe.
Old 08-12-2005, 01:45 PM
CHarris's Avatar
Anyone know where to get some used pipes? I'd hate to destroy working cats but I just might have to do it to get where i want to be. Mine are true duals into the muffler.
Old 08-12-2005, 01:47 PM
High on diesel fumes
thunder550's Avatar
Post up in thte classified section...there's gotta be some people out there with stock y-pipes sitting around.
madmann26
04-29-2020 09:17 AM
bagged7104SS
22
10-24-2015 06:14 PM
BlownHD
10-03-2015 12:24 PM
Wolftrk99
10-02-2015 08:17 AM
02AWDAWSDenali
10-01-2015 05:08 PM
Quick Reply: Gutted cats
