2004 Yukon overheating at idle
Wild shot in the dark: Have any black rubber filler pieces from around the radiator been removed or do you have any kind of skid plate that could be blocking or changing the normal airflow? Has the radiator been replaced with an aftermarket unit (it might look the same but not be as good)?
What you're describing with the hot hood latch is a symptom of clogged air passages, most likely in the condenser. It's really easy enough to take the entire radiator out and check for debris.
This every get resolved? Sound like a clogged radiator, Dex cool will build up and do this. Didn't you say it doesn't overheat while driving???
Byrdman11
09-19-2016 05:41 PM
