Adding 4l60e temp gauge/questions
Old 05-03-2010, 02:41 PM
Banned
1LOW4X4's Avatar
Default Adding 4l60e temp gauge/questions
Guys, I've read a lil on here about the temp gauges.
1. What's the best electrical one to get? Have link?
2. I guess it would be an external mount? Like under dash or gauge pod in a-pillar?
3. Is it best to install it into the test port on the side of tranny or is there a way to install into valvebody like factory?
4. How hard is this to do? I'll have the pan off to put the vette servo in.....
Thanks a bunch, any help is greatly appreciated
Old 05-03-2010, 02:50 PM
Nick™'s Avatar
first of all: what year truck?
Old 05-03-2010, 03:41 PM
SnakeOiler's Avatar
Personal preference. I like Autometer. I have the Phantom gauge because it matched my North Face gaugeface the best.
Yes, unless you want to be adventurous and install it into the I/P like I did, but mine is an '02. I don't know if that is possible on an '03+
Test port is fine. You could also weld a bung to the pan and install it like that. I have observed the same temps in both locations. Others talk of installing the sender into the cooler feed line.
On a scale of 1 to 5 wrenches (5=call the pros). I give it 2 wrenches.
You have another option of just replacing your current cluster with a cluster that has the tran temp built in. Denalis, Escalades and, I believe, HD models all came with factory tran temp gauge.
Old 05-03-2010, 03:44 PM
Jeteys5.3's Avatar
Just a second option....you could always get an Aeroforce gauge. Very easy hook up and you get a little more out of one gauge!
Old 05-03-2010, 03:50 PM
Banned
1LOW4X4's Avatar
Awesome guys. It is an 01. How did you install it in the I/p?
Is there a good place to buy an apillar that takes gauges?
Old 05-03-2010, 03:51 PM
Banned
1LOW4X4's Avatar
Tell me more!
Old 05-03-2010, 04:32 PM
Baltimore Whore
Mangled03gmc's Avatar
IMO get yourself a cluster that has the temp gauge in it..
Old 05-03-2010, 05:12 PM
Banned
1LOW4X4's Avatar
not looking to spend a couple hundred on this, got way too many other mods planned
Old 05-03-2010, 05:21 PM
Jeteys5.3's Avatar
Tell me more!
just google "aeroforce interceptor gauge" and it will come to their website where you can check it out. Except they run around 225 new i think. Could look for a used one as i see them every now and then.
Old 05-03-2010, 05:31 PM
Banned
1LOW4X4's Avatar
damn, have a link to a regular autometer one? not sure where to look or which one will work.
Quick Reply: Adding 4l60e temp gauge/questions
