How to prevent this.....
Old 07-29-2014, 03:48 PM
  #21
I have a gauge for that
Atomic's Avatar
^^ This guy would know!
Old 07-29-2014, 04:22 PM
  #22
11 sec. Truck Mod
TIM Z's Avatar
How much Rwtq are you making ?
My Previous 07' Duramax CCSB weighed 7000 lbs and made 800++ rwtq with the stock alum drive shaft , no probs what so ever even with lift blocks .
You may want to get rid of the coils and do a conventional leaf spring setup with traction bars .
FWIW I use a 3.5 " steel shaft in my silvy , I know it's shorter than what you need but I would like said above check into if it would be a better option for you .
Old 07-29-2014, 04:42 PM
  #23
axisT6's Avatar
Am I missing something here?? A linked suspension will yield better performance than a leaf sprung set up. Properly set up, links will have no axle wrap, and will transfer the vehicle weight as needed for the best traction.
Old 07-29-2014, 06:15 PM
  #24
DrX
DrX's Avatar
RWHP/RWTQ is still TBD. I think the shaft is OK as is, although it is shifting right at the calculated critical speed of 7000 RPM (6500 in the tune). Torsional yield is something like 10,600 ft-lb.
Old 07-29-2014, 09:29 PM
  #25
Custm2500's Rude Friend
1FastBrick's Avatar
Nope, Not missing a thing.
Tim Z on the other hand...
Old 07-30-2014, 05:57 AM
  #26
11 sec. Truck Mod
TIM Z's Avatar
What do you think your missing ?
I am just trying to offer another view / solution to the problem .
I'm not saying a linked suspension won't work or that they are bad , you are misunderstanding my post.
His stock rear setup isn't working , so either it needs upgraded with better parts or he could swap in a rear leaf setup fairly easily and in expensively , it's up to him .
But my leaf spring setup sucks , it only cuts 1.60s so far
Old 07-30-2014, 07:04 AM
  #27
axisT6's Avatar
Installing leafsprings would be going backwards. That would also mean undoing all the custom brackets that weren't exactly cheap. Boxed lower control arms, upgraded panhard bar, beefier sway bar, and poly bushings would definitely spruce that rear up.
Old 08-01-2014, 07:38 AM
  #28
DrX
DrX's Avatar
Originally Posted by James B.
I was advised long ago by Inland Empire Driveline that the power I was putting down with the Tahoe back in the day was better served by a steel shaft. We went with a fixed yoke on the Gear Vendors output shaft and a splined steel shaft with solid 1350 joints in between. That configuration eliminates slipyoke binding on the tailshaft and has been bullet-proof through all motor configurations. I went with the same setup on the Suburban.
Honestly, it should be breaking axle shafts or ring gears before breaking the driveline.
Like this?
Old 08-01-2014, 07:59 AM
  #29
axisT6's Avatar
Originally Posted by DrX
Like this?
Yes. That is how my truck is set up.
Old 08-01-2014, 09:37 AM
  #30
Atomic's Avatar
So is that a slip yoke on the end of the shaft with a fixed end on the pinion gear? What does the transmission side look like? Fixed?
Quick Reply: How to prevent this.....
