How Much Do You Have I Your 4L80e Swap
I have HPtuners. Is it complicated doing the segment swap? Can I simply upload a tune from a 4L80e truck and copy over my engine tune?
If I pick up a stock take out 80e and put a stall in it, can I expect it to live (reasonably) at 500 HP? Then build the transmission down the road?
Thanks for the help so far.
Can you elaborate on why you wouldn't recommend the frost harness? I was always planning on using one if and when I eventually need a 4L80. From what I understand the lockup doesn't work well with the segment swap.
What's the issue with segment swap and converter lockup. I'm learning here!
Restricted
Any good shop will charge right at $500 for the swap, and that's modding your factory crossmember and re-pinning your. Factory harness.. I've got around $600 in my tranny, $500 for the swap, $300 misc items, and $1,100 for PI tripple disc. So about 2,500 all together. Could've saved 1,000 on the whole thing, going with a cheaper converter and doing the swap myself...
2wd pays something like 4.5-5 hours labor 4wd closer to 8, most shops now are $100-120/hr labor rate, then add time for modifying xmember, harness, tune, fluids, etc, etc... You will end up $15-1800 quick on a 4wd, not including any additional time if its got a lift on it!!!
