Detroit TruTrac issues
Old 01-01-2010, 08:33 PM
Default Detroit TruTrac issues
EDIT: found out it's a detroit LOCKER he sold me, not a trutrac... all and all I'm pretty pissed, it's not what I asked or payed for. After numerous times searching I found that driveline slop is perfectly normal and acceptable for this rearend.
Old 01-01-2010, 08:49 PM
Wearin' da big hat
00ChevyScott's Avatar
Mine does not do anything like this. Sounds like something is screwed up with it
Old 01-01-2010, 08:50 PM
Thanks haha, I know something is screwed up. This is the second one I installed and previous truck was flawless
Old 01-01-2010, 08:52 PM
dlt76028's Avatar
i thought he was selling an eaton posi? different from a trutrac. anyhow, sorry to hear that, hope its not major.
Old 01-01-2010, 08:59 PM
SPAM HUNTER
2005 Silverado's Avatar
When i did mine (the first time) this same thing happened. I tore it back down and the backlash doubled...i luckily only needed to reshim the carrier.
Goodluck...
Old 01-01-2010, 09:00 PM
Wearin' da big hat
This is the for sale ad, I don't see truetrac in it at all.
https://www.performancetrucks.net/fo...d.php?t=451818
Old 01-01-2010, 09:02 PM
dlt76028's Avatar
yea in fact he even says he's too lazy to get a part number or take the plastic off to check it out
Old 01-01-2010, 09:37 PM
Where's the Beef?
viciousknid's Avatar
If it is in fact a tru-trac make sure you didn't use Synthetic fluid. If it's NOT then maybe you should?
Dunno. Throwing **** out there. Good Luck.
Old 01-01-2010, 09:41 PM
If its not a trutrac, which I THINK it is I'm going to be pissed, I specifically asked if it was, and he confirmed that it was.
It doesnt have any clutches inside, however...
the piece in between the springs, is essentially the same, however there is one on each side of the pin, basically each side of the pin has two single face pieces that mesh together, rather then two single face that mesh the same one in the middle.... and that's a locker I understand, not sure that it means this one is two...
http://www.eaton.com/EatonCom/Produc...cker/index.htm
Old 01-01-2010, 09:46 PM
SincalT/A's Avatar
If its a trutrac there would be helical gears inside.
Quick Reply: Detroit TruTrac issues
