Fuel pressure regulator vacuum/boost question
Well if you do it without the car running your running off the volts in the battery which mine is at 12.5 (in my case). With the car running my volts are 13.7.
With the truck off and turning on the pump my reads 56psi. With it running and vacuum line removed it is 58psi. Not a big difference but a difference.
