400+ RWHP Titan in the making!
I can tell you for a fact this is all a lie..... Same reason you got shunned on every titan forum, your a pathetic liar. Your numbers are not even close, your times are bullshit. Should I pull the hundreds off lies off titantalk for you? The funny part is that this is where actual fast people post and your trying to bullshit these guys....
Numbers are what they are!! I guess my old truck putting down 296/388 on PRTs Mustang dyno and my 13.9 and 14.01 passes at two different tracks at nearly 5,300 lbs raceweight with an open diff are the bs you are talking about. Guess my old Hemi Ram didn't run 8.50s 1/8 mile times either. Get your head out of your *** and understand that I really don't care what you or Outlaw think. Both of your POS's are slow!!! I wouldn't have bought a crew cab Pro-4x if going fast was what I was trying to do. I just did this to have fun with my daily driver.
Come on your truck is the real joke!!!! $8K in cams, intake and stall you paid someone else to install and tune and only ran a 12.9 stripped down to about 4,400 lbs!!!
Headers, Trutrac and Drag radials would have put my 12' right at a 13.5 1/4 mile FST. Then losing weight and lowering would have put it a solid 13.3. I know you will argue the whole way, but I am very observant and see your accomplishments and failures as a Titan group. You poured a ton of money into your huge mismatch and would have been quicker with CS2s, peak speedshop 90mm throttle body and headwork.
I really don't care about beating your POS.
N20 kits pieced together come on thats as easy as installing a hid kit.
I agree you should probably watch a/f with a gauge regardless of how fuel and spark is accomplished.
Good luck on your build.
A/F is handled by the fuel jet that is why its a wet kit. The timing could be accomplished a few different ways but changing total timing in any tuning software or handheld is not a difficult task. You could run stock timing and probably be ok, the only thing I think might give you grief is the torque management showing up because the increased power.
Some trucks (most 2wds) have a WOT restriction that prevents consant full throttle until about 55 mph. Luckily this 4wd did not have any restriction from the factory, but had a very limp wristed timing map below 3,500 rpm at WOT and was very slow to hit fuel enrichment (like all of first gear slow). I had to really work on the timing table to get the converter to flash, without spark knock prior to the nitrous coming in at 3,500ish. On motor the converter is flashing about 2,800 and I have a 1.95-2.0s 60' in 4wd hi.
Being a 14' took some time to get Uprev to unlock my stock Rom after it had been downloaded and saved.
Had to do alot of custom tuning to make a mass airflow table for my modified intake with the sleeve removed at the MAF that increases the opening at the MAF from just over 3" to ~4.8" diameter. Had to alter the MAF table and tweak the fuel compensation tables some. Not that this was a nitrous specific thing, but rather a combination change.
Not too many people of nitroused a Titan so there is not a huge database of information out there as to what way works best.
The only person whose **** stinks in this post is yours Mike. **** Titybabytitandipshits.com.
