Water/meth kit install pics
Old 06-22-2013, 06:40 PM
Random User's Avatar
Default Water/meth kit install pics
Finally got around to finishing this thing up today. The kit is from Alcohol Injection Systems and uses a 3 gallon tank with the pump mounted to the tank on the bottom.
I put it in my tool box in the bed with some other stuff to keep it all clean and out of sight.
Another shot of the tank mounted. I ran the power wire and -4 hose to the passenger side and passed it through the floor next to the hose from the air tank. I used grommets on both the tank and bed floor.
Here's where I mounted the nozzles. I had dedicated bungs welded to the new aluminum piping just for this kit. All the hoses are -4 braided stainless and you can see the Y-block I used instead of the supplied T just because I thought it looked better.
Fuzzy pic but you can see where I had another bung added just behind the BOV to run the boost line to the sensor the fires the system up by the firewall. I had that hose made myself...it wasn't supplied with the kit.
I put the supplied LED light right next to my boost gauge. Obviously it's only on when the system fires off.
And finally....had to have something to put in the tank. I don't trust washer fluid to be consistent so I grabbed 5 gallons of methanol to mix my own.
Grabbed a couple gallons of distilled water, mixed it up and the system fired perfectly on the first test.
And....that's how I spent my day today.
Old 06-24-2013, 01:44 PM
idahoblkss's Avatar
looks clean ! too bad the pics are soooo blurry .
Old 07-07-2013, 12:03 AM
Rocket468's Avatar
Did you get there kit with just a pressure switch or the one with the snow performance sticker they pulled off?
Old 07-07-2013, 09:18 AM
Just a pressure switch....and I could care less what sticker they pull off. Rebranding is so prevelant these days it just doesn't matter.
Old 07-07-2013, 06:06 PM
Blackpanther99's Avatar
Damn thats a sick setup!
thunder550
10-08-2015 04:53 PM
chacho44
08-17-2015 03:36 AM
Dezert1500
07-30-2015 02:51 PM
therock
07-25-2015 09:23 AM
Quick Reply: Water/meth kit install pics
