T bolt clamp ????
T bolt clamp ????
Can someone tell me what size of clamp I need for the throttle body? I keep blowing my coupler off at 10lbs. The clamp I have now is 4 inches..any help is apperciated.
I use cheap stainless hose clamps, then tighten down the screw section with channel locks so that the slot the band goes into barely fits and when tightened it will not slip or strip.
whats being called the adjuster crimp, in this pic.
https://www.pegasusautoracing.com/im.../3613-2015.JPG
I use either a 4.25 or a 4.50 inch Clampco T bolt clamp on a 4" coupler for my 102 TB and it holds 20+lbs no problem. Brian Tooley sells them as well as several other shops.
https://www.briantooleyracing.com/cl...41rc-0425.html
