Choice for fi Daily driver 370/402/408...Why..?
#32
I didnt see a big temp difference with my spacer, I think it becomes more relative the more you push it. We have the same intercooler core from 1900-2300. A good head porter, I like TEA but everyone has there favorite. You could go aftermarket casting or have them work a set of 317's and mill them a bit to bump compression. Throw some studs in it also while your at it.
#33
Forged pistons, some rod bolts, oiling improvements c6 pan if you can or accusump, arp head bolts, blue print oil pump, ls9 gaskets, reuse crank/rods, and spend saved on a good set of heads you reuse on your next project, or and spend money on good valetrain and cam that isnt going to make you swap springs every 15-25k miles.
get some traction on the rear if any money left, could port your blower snout cheap too, port match manifold to heads also.
#36
I have a 408 and would not do it with a stock block again.
2 seasons and I needed new pistons due to the piston going so far out of the bore.
My vote would be stock crank and rods with a set of .030 over pistons so a 370.
Get a nice set of heads instead of going all fancy on the rotating assembly
