2015 5.3 Silverado Build (blower/cam) pics/video
I bought my 15 in Oct. 2015 and immediately starting modding. I'd say it was last month when I finished up and now I want to share my build. I'll go in order of when items were installed. The truck dyno'ed at 299 stock. With Whipple (4.375 pulley) and ARH it hit 440whp. Did a pulley swap to the 4inch pulley, installed the LT4 cam, LT1 injectors and the truck hit 503whp. Last upgrade on my list is a set of Michelin tires and a 103 throttle body.
15% tint
10inch GM kicker subwoffer
Wilwood BBK
6 pistons with 16 inch front rotors
4 pistons with 14.25 in rear rotors
this kit will throw you through the windshield
1 & 7/8 American Racing Headers w/cats
Whipple 2.9 w/4.375 pulley
Hellwig front & rear sway bars
these really help with higher speed turns and tighten up the steering a good amount. Note, for the rear you need longer end links than what the kit came to make the sway bar parallel to the ground. For the front you need plates that Hellwig makes for the front but they don't include them automatically. I called and Hellwig shipped them immediately for free when I called about them.
Elite Engineering dual catch can kit
I have one can cleaning between the valley plate and blower, the other is cleaning off the drivers side valve cover.
Corsa sport exhaust
For me this exhaust is to loud with headers and a blower and had a ton of drone. I'm into loud, big muscle sounding V8's but this was over the top for a DD. I fixed it by adding a 18inch long, 3inch through Magnaflow resonator for volume and a j-pipe for drone.
cold start with corsa, without resonator or j-pipe
down shifts with corsa without resonator or j-pipe
Magnaflow and J-pipe
high country grille, tow hooks and black bow ties
i even modded my LTZ badge to fit
LT4 Cam, LT1 injectors, Manley pushrods and dual valve spring kit, 4inch pulley and belt, Whipple boost guage and more tuning. The LT4 cam was a perfect choice for my boosted DD truck since it is spec'd for a blower coming out of the Z06, it keeps VVT which gives a ton of low end punch and eliminated the boost lag and helps move that boost pressure out the whole that the baby NA cam that came stock. It adds a tiny bit lump at idle since the idle is set around 750. Once all was installed we were having a fueling issue up top and we found out there is a restrictor valve in the inlet pipe between the fuel feed and the high pressure fuel pump. It has a .165" inlet (roughly half the size of the actual fuel line) and 4x .080" outlets with a small ball and spring valve. To get a reference that is a standard .99c BIC pen next to it. This inlet is way too small to support the horsepower was after and I honestly don't know how the factory gets by at even 300hp. So i had a custom fuel line made eliminating the restriction
since i don't have a 4x4 the gauge had a perfect spot. i bought the 4x4 gauge panel for $22 and used my dremel to widen the whole then installed the gauge.
warm idle with resonator and j pipe
cold start with resonator and j-pipe
HID low beam and fog lights
15% tint
Wilwood BBK
Corsa sport exhaust
BlkHwk (05-09-2017)
thanks, I remember installing those as my first perfomrance mod and everyone asking why I needed such big brakes, one guy over 4th of July that didn't know about the other mods actually laughed when he saw them as he thought it was overkill. well i took him for a ride and about snapped his neck nailing the gas and he quickly realized i needed every bit of those brakes
yes that is with the j pipe and magnaflow. the truck lasted one week wit the corsa before those were added. actually cruising the interior noise is almost zero. i'll post a video nailing it with the windows down and cruising with the windows up so you can hear how quite it is.
