Torque Build Results
Engine Specifications:
Bore: 4.070” (Factory L92 aluminum block)
Stroke: 4” (Callies DragonSlayer)
Rods: 6.125” (Callies Ultra H-Beam)
Pistons: Manley #592770C-8 (-18cc dish), fitted with .170” wall wrist pins for boost application
Heads: Factory L-92, slight shave, dual valve springs (68cc chambers)
Head Gasket: Factory L92 (.051 thickness)
Compression Ratio: 9.8:1
Cam: Vinci Performance, DUR @ .050" 210* / 222*, LIFT .551 /.551, LSA 116* (.585 lift with 1.8 ratio rockers)
Rockers: Yella Terra 1.8 ratio adjustable
Throttle Body: 102mm Nick Williams DBW
MAF: Lingenfelter 100mm
Injectors: Siemen Deka #107962 (60 lbs/hr @39.15.psi)
Supercharger: Whipple 2.9L, 4" pulley, inter-cooled
Balancer: Innovators West 10% overdrive
Headers: ARH 1-3/4"
Vehicle:
2003 Suburban 2500 4X4
33" Tires on H2 Rims
4.10 Gears
Single 3.5" exhaust (GM Duramax muffler followed by a Walker resonator)
Going for more boost........... stay tuned!
Headers: ARH 1-3/4"
Vehicle:
4.10 Gears
Gas was 91 octane. No meth.
I ordered the 2010+ 2.9L Camaro tuner's kit. The Camaro uses the same drive dimensions as our trucks. You have the option of using the Camaro accessories or the truck ones. I use the truck one because I have Hydroboost brakes and modified the pwr steering/alternator bracket so it would rotate slightly towards the driver's side to clear the bypass and dbw TB.
LS1Tech Premium Sponsor
I think the tuner told me 31 degrees total. Gas was 91 octane. No meth.
I would like to add that my visit at Vengeance was a very positive one. The quality of work and the cleanliness of the shop that I saw really shows a high level of professionalism. Mike was awesome on the tune and shared his knowledge freely. I not only drove away with a great tune but also learned much.
BMF
I think the tuner told me 31 degrees total. Edit: I don't know the timing!
