Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
232 236 113+2 and ported fast lsxrt 102 results
Old 06-04-2010, 06:43 PM
jophuss36's Avatar
Default 232 236 113+2 and ported fast lsxrt 102 results
433 376 through unlocked 3800 yank. Up from 396 374
Old 06-04-2010, 08:09 PM
dlt76028's Avatar
That's the same cam I had in my 6.0. So you changed cam and intake? Those are some great numbers unlocked and with big heavy 33" tires.. Put some 30" stock tires on there and lock the converter and you will probably have ~480 hp, right there with Skeet. Got a graph?
Old 06-04-2010, 09:01 PM
skeet's Avatar
i would have thought you would have more torque with the truck intake?
seems like i read that the truck intake would produce more torque?, but from your numbers i am glad i went with the car intake which i gained 40+ in both areas..
but by all means they are some great numbers
Old 06-04-2010, 09:32 PM
Bumpers's Avatar
Torue is what you need esp with big tires and such.. I figured that intake would have gain more than that atleast 10 lb ft.
Old 06-04-2010, 11:22 PM
Baltimore Whore
Mangled03gmc's Avatar
TQ seems kinda low to me, but hp i good
Old 06-04-2010, 11:30 PM
jophuss36's Avatar
Thanks yaw I dyno both times with the 31.50 x10.50. But I just left the track and ran 13.11. I ran 12.96 with the same mph with the other setup
Old 06-04-2010, 11:42 PM
9 Second Truck Club
stock48's Avatar
Not bad 4x4 soaks up quite a bit of power. Was it hot this time? Maybe some KR or something going on...
Old 06-04-2010, 11:51 PM
jophuss36's Avatar
It was 20 degrees warmer but I don't think I was getting any knock retard. I did pull a 106 code
Old 06-05-2010, 01:38 AM
Bumpers's Avatar
that sucks when you spend that much money in new mods and go a lot slower lol.. Lock the converter and see what it does
Old 06-05-2010, 04:25 AM
jophuss36's Avatar
Ok while driving home from thd track I saw a 08 z06 and from a 80-105 roll I beat him (later to find out he was in 4th gear). Then he smoked me twice more. We went from 65-95 roll and I beat him again. We talked for a min and wemt from a dig I pulled hard because he just spun.... Then when I hit second gear.. Kaboom. Trans locked up!! Anyone have a 4l80e? That was my 6th 60e
Quick Reply: 232 236 113+2 and ported fast lsxrt 102 results
