TIME SLIP DATABASE
Any guesses on ET?
Old 05-02-2016, 05:35 PM
fastjweb's Avatar
Default Any guesses on ET?
truck went 11.02 at 121.2 with a 1.56 60ft, 70mm master power, 15 psi, 11 degrees to the 8th, down to 9.5 degrees due to iats on staight 93. Just installed a turbonetics 78/75 BB .96ar and 50/50 meth. Will probably be running 14 degrees of timing and 15 psi. Not sure what to expect out of it. Should be a solid 4-5 degrees more timing across the board.
Old 05-02-2016, 05:45 PM
Formerly ScreamingL
George C....'s Avatar
if the 2000 4.8 lives it should go 10s if you can duplicate the 60's youve had in the past
youre gonna flow alot more air now, what intercooler?
Old 05-02-2016, 05:51 PM
fastjweb's Avatar
your favorite George, its only the 3" ive always had. if it does go 10s, im sure it wont go much farther with the intercooler or the fuel system. Been looking at intercoolers too.
Old 05-02-2016, 05:52 PM
fastjweb's Avatar
The motor is out of my 03 that was wrecked, but same differance
Old 05-02-2016, 06:55 PM
Formerly ScreamingL
Get that treadstone it will help that turbo flow
Old 05-03-2016, 02:16 PM
SloSVO's Avatar
which treadstone is that?
Old 05-03-2016, 02:35 PM
Formerly ScreamingL
The big one
Old 05-03-2016, 06:00 PM
fastjweb's Avatar
yeah, looks like the TR1245 is the way to go. How much of a issue is it getting rid of part of the A frame. Currently the trans cooler is behind it, would like to notch cut that A frame that way it will give me added room for the 4". right now 3" in front of A frame, and grille just touches it.
Old 05-03-2016, 07:15 PM
10 Second Club
10.7XX @ 124.XX
That's my guess if the sixty foots and the weather is similar to when you went 11.02
Old 05-03-2016, 07:21 PM
fastjweb's Avatar
Originally Posted by 86 IROC
10.7XX @ 124.XX
id be happy with that lol.
TVS/HC
05-03-2016 10:41 PM
1slow07
11
05-02-2016 08:48 AM
Lowexpo
04-28-2016 11:19 AM
Quick Reply: Any guesses on ET?
