Question regarding water in transmission
Old 03-02-2017, 03:27 PM
Registered User
Ryan Hampshire's Avatar
Originally Posted by Wolftrk99
Agreed water is heavier, and thinking is if its separated and you drop the pan it should be full of mostly water, in theory anyway, other option is as has been mentioned flush the system through the cooler lines....
I was checking out the cooler line option though I don't have clear access to that part of the transmission it would seem the previous owner may of placed an extension on the line that I might be able to tap into. (could also just be a bandage for a broken line)
Wonder if I can use the side that is attached to the radiator instead and just funnel it through some tubing using a 3/8th fitting in place of the outflow line.
Old 03-02-2017, 04:41 PM
Wolftrk99's Avatar
Radiator end would be easiest and most beneficial
