84 C/10 5.3L swap... ANNOYING QUESTION....
I just picked up a FLEX FUEL intake tonight, there getting kinda tough to find. I've been looking awhile. Everything is coming together....
FYI...In case you didn't know the FF intakes use larger injectors. I think they're 33lb or 36lb vs the 26lb regular 5.3 stuff. = more fuel pressure + more flow...
im putting a 5.3/60e in a 87 c10 now.i'm using dirty dingo's adjustable motor mounts.brp racing mid length headers.stock driveshaft is gone work and shifter linkage.oil pan clears fine
Just ordered 5.3 today. PSI beehive valve springs are on the way. Cam is going to cam grinder by the end of the week. Having a RE-GRIND of GM's ASA LS1 cam...should be pretty nasty sounding, can't beat 75 bucks vs 400...
I will take pics soon and post....
I have had two of Orielly's house brand filters go into bypass on me and lean my engine WAY out, a little tough to diagnose. Spend the money and get a WIX!
