Turbo options
Old 08-25-2016, 06:07 PM
HDhotrod's Avatar
Default Turbo options
I'm about to order on3 turbo kit for my 03 2500hd 6.0 that gets used as a work truck that hauls and a toy. I can't decide between their 76 or 78. Ive researched this a ton and there is several debates about small or large turbine for a truck gets used for work? I'm leaning towards the 78, would that work? I want grunt down low but not consistently in boost
Old 08-25-2016, 06:20 PM
Ray Finkle's Avatar
Get the larger turbine in my opinion.
Old 08-25-2016, 06:40 PM
FFDP's Avatar
Either would perform just fine as you aren't going for all out power.
Even the 70mm turbo would be a great jump in performance over stock.
Old 08-25-2016, 07:56 PM
HDhotrod's Avatar
Do you think the 78 would be a dog off the line?
Idk if matters about mods but I have a 220r cam and 243 heads
Old 08-25-2016, 08:37 PM
11 Second Club
Mean Green z28's Avatar
7875 On3 on my 5.3 with a 4L80E and stock convertor and 3.42 gears and it's a dog off the line and picks up after about 2500-3000 RPM ... getting a 3200 stall shipped currently.
6865 Precision before with a 4L60E and stall was a beast amd put down 520 rwhp
6.0 may help it spool a bit earlier.
Old 08-25-2016, 09:28 PM
fctry286's Avatar
I have a 70mm in mine with the 1.05A/R housing. it builds boost nice while cruising and while WOT turbo lag is about 2800-3000 then its a rocket. at 10lbs truck made 523rwhp and I have a 5.3l.
Old 08-25-2016, 09:59 PM
HDhotrod's Avatar
Yea I think the ar for the on3 70 and 76 has a .81 ar. My trucks already a dog down low I just don't wanna choke it with the small 65 turbine.
Old 08-26-2016, 08:21 AM
Choda's Avatar
double check that AR. I thought they were 70/65 with .96 AR. I have the exact specd turbo and it lights off once i touch the throttle with my 5.3
Old 08-26-2016, 08:57 AM
BigBlock90's Avatar
I run the VS Racing 7875/.96 on my black truck and had the same results when i had the 5.3 in it. it was instant spool when touching the throttle.
Old 08-26-2016, 11:56 AM
HDhotrod's Avatar
Your right, they all have .96. so ita matter of turbine size I guess. So you both have a 78/75 and it lights quickly?
Quick Reply: Turbo options
