Need E-Fan harnes
I have a 2000 GMC 1500 and bought a new radiator and OEM fans from the salvage yard ...... I need the wiring harness to help complete the install.
THANKS! |
I was gonna say Scottyboy usually has them but I see you sent him a PM. He does a great job cleaning them up and shipping them out.
I guess I will wait until he reappears!
THANKS! |
If u pulled the fans from the junk yard u should have got the factory harness with fuse block. Get the pigtail with wiring to tie into the ecm. The fans fuse block goes beside the factory fuse block near the firewall. Hook up power and ground. Easy swap!
Nelson performance has a really nice e-harness that works great and is really well built
Originally Posted by BlackPanther6.0
(Post 5426669)
Ive ran a nelson performance harness for yrs without issues. Great harness for the money.
But if your on a budget the factory harness is hard to beat. |
Yea I've had their new harness for 1 and a half years and I have it running at the highest speed for both fans with no problems so far.
Originally Posted by brandon6.0
(Post 5426667)
The closest wrecking yard that had one was 70 miles away and they have guys that pull parts with cutting torch and shears! http://myfolderz.com/pics/Cut001.jpg http://myfolderz.com/pics/Cut002.jpg |
(Post 5426669)
THANKS for the tip, the wires were a little short between the two fans, but it works like it should even after I stretched them to go on the plugs. |
