Shit, I forget dad has all the presses for reloading. A friend told me that about the 223's, perhaps he was mistaken, or it was on a particular combo. So my goal is rather low it sounds like. Good. My mounts are schedules to come in tmmrw, then sight it in, and go hunting.
Originally Posted by charcold-bowtie
(Post 4714085)
You can fine tune it with changing the gas port size in the barrel. If you had to. Or a different buffer.
I have a funny issue with my 16" 6.8 AR. Every now and again it will soot up a whole case after its been shot. Most of them have a good seal on the neck. But the suppressor might be making it do that now that i think bout it,doh. My next build is a 10.5" 300blackout :D. Cant wait to be really quiet and still semi auto. |
(Post 4714145)
See if you can find some of these to load. They are pretty nasty on critters.
http://www.midwayusa.com/viewProduct...tNumber=796980 |
Any particular reason you went with a 204 as opposed to the "normal" varmit calibers?
(Post 4714649)
But it peters out quick as far as ftlbs are concerned and figured he might want to play with coyotes during the day later on down the road.
(Post 4714728)
Velocity (fps) / Energy (ft-lbs) Muzzle-----100 yd-----200 yd---300 yd---400 yd---500 yd 4225/1268 3645/944 3137/699 2683/512 2272/367 1899/256 The 40gr V-MAX is a fair amount better, check out this chart (http://www.hornady.com/images/ballis...ics_charts.pdf). |
(Post 4714728)
Thats why i went with a 9 twist 22-250 shootin 80gr bergers. Stays supersonic out to 1400 yds |
